Error Message Non linear solver did not converge at Time=0.005073
Posted 20 giu 2025, 10:26 GMT-5 Particle Tracing for Fluid Flow, Results & Visualization, Studies & Solvers Version 6.1 0 Replies
i am trying simulating a water droplet impacting on a flat surface with particles. initially for optimization i am trying to observe results only with a single particle which is placed directly below the bubble impact position. here i am using laminar flow level set module and particle tracing module. the issue is with the convergence of non linear solver. i used user defined mesh with extra fine where the drop and particle is to move .What changes in the solver setting or the model should i do to get convergence.
Hello Chinmay Patil
