How to draw a spherical dome?
Hello all,
I am very new to Comsol. I am trying to draw a three dimensional spherical dome and mate it with a rectangular box. I have successfully drawn the box with a circular opening on one face. I would really appreciate it if someone could point me to the right direction.
Thanks in advance
Amar
4 Replies Last Post 16 ago 2012, 11:42 CEST
Konstantin Barzilovich
Posted: 1 decade ago 8 ago 2012, 08:10 CEST
As I understand, you need to use some boolean operations with your geometry objects. Right click on Geometry 1, Boolean operations.
Posted: 1 decade ago 8 ago 2012, 09:48 CEST
my suggestions would be:
2D shell (in 3D): draw a sphere and a block intersecting, then subtract the block from the sphere, convert to 2D shell
3D solid: draw 2 spheres, concentric for inner and outer boundaries (difference = thickness), thena block to intercept, take the difference "outer sphere" - "inner sphere" - "block"
2* alternative one sphere with a layer, subtract the block, delete unwanted entities for inner domains
Hi my suggestions would be: 2D shell (in 3D): draw a sphere and a block intersecting, then subtract the block from the sphere, convert to 2D shell 3D solid: draw 2 spheres, concentric for inner and outer boundaries (difference = thickness), thena block to intercept, take the difference "outer sphere" - "inner sphere" - "block" 2* alternative one sphere with a layer, subtract the block, delete unwanted entities for inner domains -- Good luck Ivar
Posted: 1 decade ago 9 ago 2012, 01:24 CEST
Thanks a lot for your replies everyone! I was able to create the desired geometry thanks to your tips. I truly appreciate your help.
Amar
Thanks a lot for your replies everyone! I was able to create the desired geometry thanks to your tips. I truly appreciate your help. Amar
Posted: 1 decade ago 16 ago 2012, 11:42 CEST
Dear all
I want to draw a spherical dome but in 2D axisymmetric mode (i.e a 2D dome) can somebody guide me how can it be drawn in comsol 3.5a. Actually the dimensions of this dome are in micrometers (height = 297micrometer and base radius = 25micrometer).
Dear all I want to draw a spherical dome but in 2D axisymmetric mode (i.e a 2D dome) can somebody guide me how can it be drawn in comsol 3.5a. Actually the dimensions of this dome are in micrometers (height = 297micrometer and base radius = 25micrometer). Thanks
