How to prescribe displacement amplitude
Hi all
Is it possible to prescribe the displacement amplitude of a boundary in XYZ coordinate? For instance, in the attached file I try to change the amplitude by scaling the "Prescribed in y direction" by a factor of 1000 but the amplitude is still the same.
Derry
3 Replies Last Post 9 apr 2019, 22:55 CEST
Posted: 6 years ago 8 apr 2019, 14:33 CEST
Hi Derry,
Deformation plots are automatically scaled, so for a linear problem two plots that differ only by the magnitude of the deformations can look very similar but if you plot the displacements and look at the color scale you should see that they are in fact different in their magnitudes.
Jeff Hiller
Hi Derry, Deformation plots are automatically scaled, so for a linear problem two plots that differ only by the magnitude of the deformations can look very similar but if you plot the displacements and look at the color scale you should see that they are in fact different in their magnitudes. Best, Jeff
Posted: 6 years ago 9 apr 2019, 22:52 CEST
Hi Jeff:
Thanks a lot! Just checked that indeed it is true. Didn't expect that, but it is a cool feature.
If I really want to visualize unscaled deformation, i.e. the unscaled deformed geometry, how can I do so?
Thanks, Derry
Hi Jeff: Thanks a lot! Just checked that indeed it is true. Didn't expect that, but it is a cool feature. If I really want to visualize unscaled deformation, i.e. the unscaled deformed geometry, how can I do so? Thanks, Derry
Posted: 6 years ago 9 apr 2019, 22:55 CEST
OK I found the answer, just change the Scale factor in the Defomation settings
