2 decades ago
19 set 2010, 04:57 GMT-4
Hello
it could be due to solidworks versions too, SW changes their format for each release (this makes life difficult even for us having the full CAD verson as SW is not downwards compatible, only "upwards"). I usually use the Parasolid .x_t format as this one evolves less and there are less version compatibility issues. From SolidWorks you can easily generate Parasolid files with a save as, aqt part or assembly level.
Note this is only for 3D files, 2D is limited and prt files are full 3D.
You need the CAD or livelink module to import these files. The main intereest with live-link is to run SolidWorks AND COMSOL together and have COMSOL update the geometry to search for shape optimisations. If you do not do such links (or do not have a powerfull enough PC to have both open simultaneously, then using simple file transfer works very well (witout the linked shape optimisation though)
Hello
2 decades ago
19 set 2010, 14:46 GMT-4
Ivar, thank you very much for your reply!
I will ask for the file in Parasolid, .x_t, format instead. Hope it will work out.
/Daniel
/Daniel
16 nov 2010, 09:34 GMT-5
Did you have success with the parasolid export into comsol?
16 nov 2010, 09:37 GMT-5
Yes, it worked fine!
16 nov 2010, 09:45 GMT-5
Thanks for the quick reply. I am running solidworks 2010 and comsol 3.5 .....Any known problems with this?..Thanks, Sam
16 nov 2010, 09:49 GMT-5
One more question. Was you importing a solidworks assembly as a parasolid with multiple parts? Thanks, Sam
