Jeff Hiller
COMSOL Employee
24 set 2015, 08:27 GMT-4
I am not sure I understand what you mean by "without just having the "import"-bracket ", but from the rest of your post it seems that you can use Insert Sequence.
24 set 2015, 08:39 GMT-4
Hi Jeff,
that's actually what I mean. But how do I export a sequence? Haven't found the button for that, yet :/ .
Hi Jeff,
Jeff Hiller
COMSOL Employee
24 set 2015, 09:54 GMT-4
You don't need to export a sequence out of the old file (the one that contains the geometric sequence you want to pass to a new file).
In the new file (the one into which you want to insert the sequence), you add an Insert Sequence node and in that node's settings you point to the old .mph file.
That's it.
In the new file, you'll notice that COMSOL brings in all the geometry parameters for you.
That's it.
25 set 2015, 02:31 GMT-4
Thank you so much!
That made it and it's amazingly easy :). That will make further projects much easier.
Have a nice weekend,
Philipp. :-)
Thank you so much!
Philipp. :-)
9 years ago
4 mag 2017, 20:28 GMT-4
Is it possible to convert a Comsol imported geometry (or the geometry file itself- mphbin) to the original sequence without having the original simulation? Deleted it by mistake.
