Edgar J. Kaiser
        Certified Consultant
                                3 set 2015, 12:58 GMT-4
                                                    Hi Levin,
I increased the tolerance factor in the 'Fully Coupled' node from 1 to 10 and it solves. This issue may arise from the large aspect ratio of the long thin beam.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
                            Hi Levin,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
                                Henrik Sönnerlind
        COMSOL Employee
                                4 set 2015, 03:04 GMT-4
The model is ill-conditioned because it is undamped and the frequency response sweep passes close to a natural frequency. The solution exactly at a eigenfrequency is infinite, meaning that the dynamic stiffness matrix is singular there.
Edgar's solution makes it possible to solve somewhat closer to the singular point because the ill-conditioning check is modified somewhat, but it does not address the underlying problem.
Henrik
Henrik
                                Edgar J. Kaiser
                                4 set 2015, 06:57 GMT-4
                                                    ... yes the damping, I miss it at times, something to be looked at first ...
Edgar J. Kaiser
www.emphys.com
Edgar J. Kaiser
