3 set 2015, 19:42 CEST
You have not told us which pressure "p" your formula is valid, is it for the pA absolute pressure or the Gauge pressure around "0", and if the latter which Gauge definition ?
I suspect that is the issue you are facing (but it might be something else), if you check the materials dependent on the pressure they are mostly defined w.r.t. the absolute pressure pA in the material section, to allow COMSOL to solve for the Gauge pressure "p" which is situated close to "0" to minimise numerical scaling error.
4 set 2015, 15:14 CEST
Ivar thanks for your suggestion
p used is gauge pressure
so now what can I do?
5 set 2015, 00:02 CEST
well then if it is really "p" that is becoming negative (something often normal if its "small") and your formula does not like a negative "p" then you should check your BC to see if there is not something in the starting point that might induce a negative pressure "p".
Or move your initial values to a clearly positive "p", or make your formula -p compatible ...
I do not see many other ways
Sven Friedel
COMSOL Employee
5 set 2015, 00:30 CEST
Hi Mahesh,
make sure that your initial value of p is not set to zero. By numerical fluctuations it might always become negative in this case. If this does not help, abs(p). If this does not help either, provide the model. NOte that also 0.3839*(p)/spf.sr is critical, as for the initial model spf.sr might be zero.
Sven
Hi Mahesh,
Sven
