Bug with Solidworks livelink in Comsol ?
Posted 28 feb 2014, 10:26 CET Interfacing, Geometry Version 4.4 1 Reply
Hi.
We recently started using Comsol for Cathodic protection analysis and we are using Solidworks for modelling.
In some of our models we get this issues that we loose the selections and need to manually create new selections.
The way we normal create selections is by adding materials to the different bodies inside Solidworks and when we synchronize we can use these materials as selection sets.
This is working fine in some simple projects but for recent projects we are getting into this issue usually when we are at the mesh operations. If i Choose Domain i can see the selecion from Solidworks in the entity drop down list. But when i select it, nothing happens. And then i need to manually create new selections for all those faces/elements etc.
Anyone else had this issue? Or is there a solution to this?
Best Regards
Roy Salminen
Senior Engineer
Deepwater Norway AS
Best Regards
Roy Salminen
Senior Engineer
Deepwater Norway AS
1 Reply Last Post 5 mar 2014, 18:13 CET
