solver sequences
Posted 17 ago 2013, 15:54 CEST Fluid & Heat, Heat Transfer & Phase Change, Studies & Solvers Version 4.3, Version 4.3a 0 Replies
what i need is a very long term simulation (i.e., 25 years) and I am using pipe flow module which assumes the pipe and 1D and the heat transfer module which assumes the other domains (ground) as 3D domain.
I want to do use a stationary sover and solve for fluid flow (pressure and velocity would be the outcomes) and as these two parameters do not change much with time I solve the solution and use them as initial condition for my transient heat transfer in a time dependent solver.
this used to work in the normal turbulent flow module (3D) but as I switched to pipe flow module (nipfl) it looks like it does not work and two steps are not linked at all.
your help is much appreciated.
ASAL
Hello Asal Bidarmaghz
