muliple geometries
I know that you assign properties by using the x,y,z coordinates, and directly to the elements.
My problem is this: I have a rectangle, that I want to dub divide into 500 triangles. Each triangle, I want it to have a different material property.
Is any way I could mesh this domain, and the triangles produced, used as different domains?
4 Replies Last Post 7 mar 2013, 07:18 CET
Posted: 1 decade ago 6 mar 2013, 18:41 CET
by default the GUI is set up so that you define N domains, and attribute at most N material, one to each material. Now having one domain that is subdivided by "math" and not geoemtry is not the standard for the GUI interface (easier to tweak via programming).
But you have something similar if you look into how the models of auto adapting models, where the results changes the material property locally, via a new variable from solid to "void". See the model library loaded knee or adaptive bridge structure.
This might inspire you (it's all done from the GUI without external programming ;)
Hi by default the GUI is set up so that you define N domains, and attribute at most N material, one to each material. Now having one domain that is subdivided by "math" and not geoemtry is not the standard for the GUI interface (easier to tweak via programming). But you have something similar if you look into how the models of auto adapting models, where the results changes the material property locally, via a new variable from solid to "void". See the model library loaded knee or adaptive bridge structure. This might inspire you (it's all done from the GUI without external programming ;) -- Good luck Ivar
Posted: 1 decade ago 7 mar 2013, 00:53 CET
Hi Ivar,
Thanks for the reply. The way I tried to do it, was through a matlab function and the use of inpolygon command. But it is painfull slow.
For instance,
I extract the triangulation from comsol
[A1,B1]=mphmeshstats(model,'mesh1');
inv_mesh_tri=B1.elem{1,2}'+1; % Remember, Comsol is zero based
inv_mesh_coords=(round(1e5*[B1.vertex(1,:)' B1.vertex(2,:)'])/1e5);
and then make a function for the next run, where I define a matlab function find_tr2(x,y)
function ind=find_tr2(x,y)
load('inv_mesh_coords.mat');
load('inv_mesh_tri.mat');
load('dx.mat');
ind=zeros(length(x),1);
SI=zeros(length(x),1);
for i=1:length(inv_mesh_tri)
xv=[inv_mesh_coords(inv_mesh_tri(i,1),1) inv_mesh_coords(inv_mesh_tri(i,2),1) inv_mesh_coords(inv_mesh_tri(i,3),1) inv_mesh_coords(inv_mesh_tri(i,1),1)];
yv=[inv_mesh_coords(inv_mesh_tri(i,1),2) inv_mesh_coords(inv_mesh_tri(i,2),2) inv_mesh_coords(inv_mesh_tri(i,3),2) inv_mesh_coords(inv_mesh_tri(i,1),2)];
t=inpolygon(x,y,xv,yv);
SI(t==1)=i;
end
for i=1:length(dx)
ind(SI==i)=dx(i);
end
ind(SI==0)=mean(dx);
Hi Ivar, Thanks for the reply. The way I tried to do it, was through a matlab function and the use of inpolygon command. But it is painfull slow. For instance, I extract the triangulation from comsol [A1,B1]=mphmeshstats(model,'mesh1'); inv_mesh_tri=B1.elem{1,2}'+1; % Remember, Comsol is zero based inv_mesh_coords=(round(1e5*[B1.vertex(1,:)' B1.vertex(2,:)'])/1e5); and then make a function for the next run, where I define a matlab function find_tr2(x,y) function ind=find_tr2(x,y) load('inv_mesh_coords.mat'); load('inv_mesh_tri.mat'); load('dx.mat'); ind=zeros(length(x),1); SI=zeros(length(x),1); for i=1:length(inv_mesh_tri) xv=[inv_mesh_coords(inv_mesh_tri(i,1),1) inv_mesh_coords(inv_mesh_tri(i,2),1) inv_mesh_coords(inv_mesh_tri(i,3),1) inv_mesh_coords(inv_mesh_tri(i,1),1)]; yv=[inv_mesh_coords(inv_mesh_tri(i,1),2) inv_mesh_coords(inv_mesh_tri(i,2),2) inv_mesh_coords(inv_mesh_tri(i,3),2) inv_mesh_coords(inv_mesh_tri(i,1),2)]; t=inpolygon(x,y,xv,yv); SI(t==1)=i; end for i=1:length(dx) ind(SI==i)=dx(i); end ind(SI==0)=mean(dx);
Posted: 1 decade ago 7 mar 2013, 01:25 CET
The problem is that comsol calls many times this functions (by providing x,y) and not just once.
Posted: 1 decade ago 7 mar 2013, 07:18 CET
I would say, if you cannot implement a field variable to control locally your material values, then use matlab to create N domains, and N materials, but it's tedious I agree. I do not see of any other way.
But there are many others out here having a lot of good ideas ;)
Hi I would say, if you cannot implement a field variable to control locally your material values, then use matlab to create N domains, and N materials, but it's tedious I agree. I do not see of any other way. But there are many others out here having a lot of good ideas ;) -- Good luck Ivar
