Time Dependent Boundary Condition...
Hi...I'm working with the Heat Transfer Module, and I need to implement a time varying boundary condition (The temperature in one wall changes in time). I have experimental data of the temperature (boundary condition) in form of an array, and of course and array of time (sample time).
Can I implement a time dependent boundary condition in a form of array (Temperature vs Time)???
Edwin
3 Replies Last Post 26 mag 2011, 09:55 CEST
Hello Edwin Insuasty
Jorge Arturo Soto Puente
Posted: 2 decades ago 28 apr 2010, 22:20 CEST
Hi Edwin, i'm working with the crystallization of polyethylene.
The growthvelocity in one of the boundaries changes with the temperature.
The temperature is a time dependent condition because the polymer is cooling.
Could you help me to change the T as a function of the time.
Thanks a lot
Jorge SOTO
Hi Edwin, i'm working with the crystallization of polyethylene. The growthvelocity in one of the boundaries changes with the temperature. The temperature is a time dependent condition because the polymer is cooling. Could you help me to change the T as a function of the time. Thanks a lot Jorge SOTO
Posted: 2 decades ago 29 apr 2010, 08:15 CEST
for me you shold be able to replace any cnstatn value by a function be it analytical (time dependent) or piecevise developed based on data points.
Try it out on a very simple case in th to convince yourself
Have fun Comsoling
Hi for me you shold be able to replace any cnstatn value by a function be it analytical (time dependent) or piecevise developed based on data points. Try it out on a very simple case in th to convince yourself Have fun Comsoling Ivar
Posted: 1 decade ago 26 mag 2011, 09:55 CEST
Hi Boys,
let's check it out:
courses.cit.cornell.edu/bee4530/miniexamples/timevary_comsol.pdf
Gabor
Hi Boys, let's check it out: courses.cit.cornell.edu/bee4530/miniexamples/timevary_comsol.pdf Gabor
