Batch Sweep with nested Parametric Sweep - Change set of parameters dependent on batch sweep parameter.
Posted 6 feb 2025, 03:57 GMT-6 Studies & Solvers, Modeling Workflow, User Interface Version 6.3 0 Replies
Hello!
I'm currently trying to set up a parametric sweep nested within a batch sweep.
I'm facing the problem, that dependent of the parameter of the batch sweep, the list of parameters in the parametric sweep changes dependent on the current parameter of the batch sweep.
My idea was to do something like this: Let's say I have n as the parameter of the batch sweep, so I was thinking to implement an if-clause in the parameters for the parametric sweep like:
if( n == 100, 500 200 100, 200 100 0)
Sadly I don't get the syntax to work. I hope to find any help here!
Thanks in advance.
Hello Lukas Böcker
