EFFECTIVE INDEX
Hi eveybody. Actually I am trying to plot effective index of PCF with variation of diameter in COMSOL.I could not know how to put the diameter values and where to put.Please help me in this regard.I am using version 4.3.0.151.Thank you.
3 Replies Last Post 15 dic 2012, 09:26 GMT-5
Posted: 1 decade ago 13 dic 2012, 01:33 GMT-5
check the Results derived variable node, and populate this one for your effetve index, this should make a table, that you can then plot by clicking on the "plot" icon of the table tab
Hi check the Results derived variable node, and populate this one for your effetve index, this should make a table, that you can then plot by clicking on the "plot" icon of the table tab -- Good luck Ivar
Posted: 1 decade ago 14 dic 2012, 08:38 GMT-5
Thank you sir.
Thank you sir.
Posted: 1 decade ago 15 dic 2012, 09:26 GMT-5
do I have to define a relation between diameter and effective index first in parametric section COMSOL 4.3.151? Is parametric sweep is needed ?Thank you
Hi do I have to define a relation between diameter and effective index first in parametric section COMSOL 4.3.151? Is parametric sweep is needed ?Thank you
