Using Batch File on COMSOL
Posted 1 nov 2023, 18:06 GMT-4 Heat Transfer, HPC & Cloud Computing Version 6.1 1 Reply
Hello, I am running COMSOL 6.1 and am attempting to run a series of time dependent heat transfer studies using a batch file in the command window. It seems to recognize the batch file, but it gives following error: 'comsolbatch' is not recognized as an internal or external command, operable program or batch file.
The batch file contains the following:
comsolbatch -inputfile Test1.mph -outputfile Test1_solved.mph comsolbatch -inputfile Test2.mph -outputfile Test2_solved.mph
Any help would be appreciated. Thanks.
