importing mesh .vrml and having geometry
I have imported mesh with a file .vrml and Comsol doesn't recognize it's geometry, that is to say, I have no subdomains in "physics".
I tried to create geometry from mesh but in the guide, it's used only for refine the mesh or use an adaptative solver. My computer crash when I would like to create geometry from mesh.
I don't know what I have to do.
Thanks.
Marie
6 Replies Last Post 17 feb 2010, 09:22 CET
Posted: 2 decades ago 16 feb 2010, 17:11 CET
Comsol can't considere a volume with a 3D surface meshes ??
Posted: 2 decades ago 16 feb 2010, 17:14 CET
Normally it should, I don't know where is the problem!!especially that the program crashes!!!
It can be your file. try to load your file with another soft and take a look on its geometry.
Or try to coerce your geometry to solid after importing it in Comsol
I hope it helps
Cheers
Hi, Normally it should, I don't know where is the problem!!especially that the program crashes!!! It can be your file. try to load your file with another soft and take a look on its geometry. Or try to coerce your geometry to solid after importing it in Comsol I hope it helps Cheers
Posted: 2 decades ago 16 feb 2010, 17:38 CET
thanks for your reply.
Comsol imported it and I can see in Comsol how it looks like, but when I go into physics, I can't check a subdomain, there is nothing.
I can't check boundaries too ...
I don't know why ...
Coerce to solid did nothing.
Marie
thanks for your reply. Comsol imported it and I can see in Comsol how it looks like, but when I go into physics, I can't check a subdomain, there is nothing. I can't check boundaries too ... I don't know why ... Coerce to solid did nothing. Marie
Posted: 2 decades ago 16 feb 2010, 19:07 CET
If it is convenient, you can post the .vrml file, I will try to load it with Comsol and take a look.
Posted: 2 decades ago 17 feb 2010, 09:11 CET
I can't attached the file on this website, I don't manage it.
Do you have an email ?
Thank you very much !
I can't attached the file on this website, I don't manage it. Do you have an email ? Thank you very much !
Posted: 2 decades ago 17 feb 2010, 09:22 CET
Usually, when we import a 3D surface mesh, comsol recognize directly a volume ?
