Importing Mesh from Mesh Generating Software
For more complicated geometries I usually have trouble getting COMSOL to mesh my geometry. I was wondering if anyone has had any luck importing a mesh generated from another program. If so what package did you use to generate the mesh? What problems arose when COMSOL tried to solve on the imported mesh?
Erik
3 Replies Last Post 15 set 2012, 11:25 CEST
Posted: 1 decade ago 12 set 2012, 12:51 CEST
I have no experience with importing to Comsol, but from experience with other software packages: stay away.
I would estimate the likelihood of everything going as you want to be very low.
You will probably spend more time importing a mesh than it would take to mesh it in Comsol.
When you have complicated structures, meshing is very important, using an automatic mesh might increase computation time greatly.
I have no experience with importing to Comsol, but from experience with other software packages: stay away. I would estimate the likelihood of everything going as you want to be very low. You will probably spend more time importing a mesh than it would take to mesh it in Comsol. When you have complicated structures, meshing is very important, using an automatic mesh might increase computation time greatly.
Posted: 1 decade ago 13 set 2012, 18:18 CEST
Thanks for the reply. I was told that Cubit meshing software from Sandia National Lab was very powerful and often provided better mesh than built in meshers for many FEM packages(HFSS, COMSOL, etc.). I thought I'd bounce the idea of mesh imports off the experts here before I invest too much time. I appreciate your insight.
Erik
Thanks for the reply. I was told that Cubit meshing software from Sandia National Lab was very powerful and often provided better mesh than built in meshers for many FEM packages(HFSS, COMSOL, etc.). I thought I'd bounce the idea of mesh imports off the experts here before I invest too much time. I appreciate your insight. Erik
Posted: 1 decade ago 15 set 2012, 11:25 CEST
but have you fully understood the COMSOL approach, with physics on the domains and boundaries (not on the mesh) ?
So with imported mesh, how do you map back your mesh to domains and boundaries ?
Hi but have you fully understood the COMSOL approach, with physics on the domains and boundaries (not on the mesh) ? So with imported mesh, how do you map back your mesh to domains and boundaries ? -- Good luck Ivar
