Computing S-parameters
Posted 30 ago 2022, 22:28 CEST Version 6.0 2 Replies
Hi everyone,
I would like to compute S-parameters. As it is known that the S11 parameter describes the reflections, and the S21 parameter measures the wave that is transmitted through Port 2 when the waveguide is excited at Port 1.
S11= (Reflected Energy/ Incident wave), and the S11 value should be near zero for the perfect case.
S21= 1 - S11, and the S21 value should be near one.
I have used the S parameters that are available as built-in expressions, ready for evaluation in postprocessing but I got S11= -1.2194E13 and S21= 5.6967E12, which are incorrect values.
I have tried another way which is creating the Global Evaluation node and writing in the Expression section the below equations:
intA(emw.Qrh)/(Port input power) >> for Absorption
(intR(-emw.Poavx))/(Port input power) >> for Reflection
intT(emw.Poavx)/(Port input power) >> for Transmission
(intR(-emw.Poavx)+intA(emw.Qrh)+intT(emw.Poavx))/(Port input power) >> for total (A+R+T)=1
However, I still have the same incorrect results, as shown in the attached COMSOL file
Would you please show me how I can compute the S parameters correctly?
Thanks in advance,Manal
