Exporting simulation end time in Parametric study
My 2D heat transfer study is transient and the simulation stops when a particular boundary reaches desired temperature or it will run until the specified end time (eg: 100 steps).
If the stopping criteria is satisfied at 60 steps, how do I print or export this time-step number? Currently, I created a time vs temperature 1D plot and I am copying the table data to excel manually to check the last time step value.
I should be able implement the same in paramteric study such that my output table will have 2 columns. First column with paramter combination details and second column with last time step value for the corresponding combination.
Additionally, I also want to export the above mentioned 1D plot that shows the time vs temperature for each combination in the paramteric study.
Thank you.
Best Regards, Saketh Bharadwaj
0 Replies Last Post 7 apr 2022, 09:34 GMT-4
Hello Polina Pirch
