Convergence problem
I am trying to simulate the water-air bubble (turbulence) flow. My model works fine for certain velocity (lower velocity) however, when I try running the simulation with higher velocity I get the convergence issue. Can anyone suggest me what could me the issue?
2 Replies Last Post 30 nov 2021, 20:00 CET
Amin Kazemi Postdoctoral Researcher, University of Toronto
Posted: 4 years ago 30 ott 2021, 17:46 CEST
You have not provided enough detail of your model. However, one way to tackle this problem is to use the solution of the lower velocities as the initial condition for the higher velocities.
Posted: 4 years ago 30 nov 2021, 20:00 CET
Hello Amin, I was using bubbly flow but I think this model only works when the volume fraction of the dispersed phase is low. Use of mixture model solved the issue.
