20 degrees phase shift
If i want to give 90 degrees phase shift simply i can give "i" ,but if i want 20 degrees phase shift can i apply simply "i-70",will it work
3 Replies Last Post 28 mag 2012, 08:40 GMT-4
Posted: 1 decade ago 28 mag 2012, 06:26 GMT-4
the phasor approach is in radians not in degrees, so use rather:
V0*exp(i*pi*Phase_in_degrees/180)
By the way you should check the sign convention, if you use a + or a - in front of your "i"
Hi the phasor approach is in radians not in degrees, so use rather: V0*exp(i*pi*Phase_in_degrees/180) By the way you should check the sign convention, if you use a + or a - in front of your "i" -- Good luck Ivar
Posted: 1 decade ago 28 mag 2012, 08:34 GMT-4
Instead of this may give like this
90 degrees=exp(j*pi/2)
45 degrees=exp(j*pi/4)
is it correct
Instead of this may give like this 90 degrees=exp(j*pi/2) 45 degrees=exp(j*pi/4) is it correct
Posted: 1 decade ago 28 mag 2012, 08:40 GMT-4
That look s fine, normally i and j are synonymes (try it out in a parameter field of COMSOL)
Hi That look s fine, normally i and j are synonymes (try it out in a parameter field of COMSOL) -- Good luck Ivar
