Simulation results dont match analytical ones
Posted 12 dic 2011, 09:02 CET Version 4.2 8 Replies
I m trying to simulate a surface meshed by shell elements with constraint at one end and a vertical force in the opposite end.
I m running the simulation and everything seems fine except that the result of the surface decline defer from the analytical result by 15 percent. Despite the fact that the forces and material moduli account for small elasticity.
When i m trying to do such a comparison for a thin and long beam the anayltical calculation of the decline and the simulation result are perfectly the same.
What could be the problem?
thx a lot
have you checked that your results are mesh independent ? and that you respect the shell hypothesis (at least a thin element, check the doc for the rest)
Mostly I'm happy with 5-10% coherence for FEM, particularly when using "simplified" models
My model is basicly a surface with length a width equal to 1 cm. The Shell's thickness has been defined as 0.3 mm (and i assume that this thickness is thin enough).
I m only trying to deal with Small Elasticity so the Z deformation resulted in approximatly 3*10^-6 [m] at the edge where the vertical Z force has been defined (the force per length is 3.6*10^-6 N). The analytical decline calculation produced 3.555*10^-6 [m] ( Z deformation ).
As far as i see, the results are not really mesh independent, because refining the mesh is changing the results by almost 10 percent.
Another strange thing is that although the force (per length) has been defined for the entire edge, i get in the results parabolic Z deformation when looking down the X direction of the surface, instead of a uniform Z deformation per X (The edge with the force has a normal in the X direction).
I hope this added information would help.
thx a lot
why should you get a uniform linear deformation ?, that is what I expect from a force load, you will get an arc of a circle if you load with a pure moment. But I'm not 100% sure I got you coordinates & load right.
In anycase I find your simulation and analytical results rather close 45/3600 is about 1.25% given all assumptions on the analytical and FEM I'm not surprised
Unfortunately the comparison should be between the analytical Z deformation, which resulted in 3.55*10^-6 [m] to the result of the simulation which resulted with 3*10^-6 [m]. So the error is about 15 percent.
The model is a surface with width and length both equal to 1 cm. The surface is meshed with Shell elements with thickness of 0.3 mm. There is a constraint at one edge and force load at the opposite edge equals to 3.6*10^-6 [N/m].
The 2 other edges are free.
Thank you
you have forgotten to tell us the material used
I get 2.5e-9 mm for "structural steel" in 3D shell 1cm^2 and 0.3 mm thick, with 5854 elements
and 2.37e-9 mm for a 2D "solid" model with 802 elements
all in linear theory for me rather coherent
Module Young, E, is 150 kPa and poisson ratio is 0.495.
My simulation result was 3.0382*10^-6 [m] for the maximum Z deformation, while the analytical result is 3.555*10^-6 [m].
Thank you
I do not get the same values, but I suspect that my model is not correct, and that I must have missed something from your description.
Another point not to forget, are you using a max or an average displacement ? as depending on how you define your model these two might differ. For precision measurements, I always take an average over a boundary as my driving value, it's too easy to get a "hot spot" and conclude from a peak
Suggested Content
- FORUM I really dont understand...... Help me..
- FORUM Frequency transient dont work
- BLOG How to Model Residual Stresses Using COMSOL Multiphysics
- KNOWLEDGE BASE Invalid Degree of Freedom Name
- KNOWLEDGE BASE Manually Setting the Scaling of Variables
