Global Definitions - Help
I am trying to define a wavelength variable in Global Definition > Parameters. I want to place this variable called 'lambda' in Study 1 > Step 1: Mode Analysis > Mode analysis frequency. There I have written "c_const/lambda" after defining it in Global Definitions but I get error message when I try to run the simulation.
Any help on what I can do to fix this?
Have version 4.1.
Many thanks in advance.
EDIT:
What is the difference between parameters and variables in COMSOL?
2 Replies Last Post 6 mag 2011, 13:44 CEST
Posted: 1 decade ago 5 mag 2011, 14:53 CEST
I believe that lambda is already used by COMSOL, so call it my_lambda, then probably it wiull work.
Be aware that many 1 lettres names are alread used up, and some greek names too
Hi I believe that lambda is already used by COMSOL, so call it my_lambda, then probably it wiull work. Be aware that many 1 lettres names are alread used up, and some greek names too -- Good luck Ivar
Posted: 1 decade ago 6 mag 2011, 13:44 CEST
You are correct, that was my problem. =)
Thanks!
You are correct, that was my problem. =) Thanks!
