Comsol 4.1 Cluster Start Errors
Posted 28 apr 2011, 16:34 GMT-4 3 Replies
I'm trying to get comsol 4.1 to work on our linux cluster (open suse 11.1) in order to solve much larger models than what I can do currently do on one computer.
I VNC to one of the computers on campus (I'm a grad student) and can successfully boot the mpd daemons. For now I boot only 2 nodes.
I can see they're active with "comsol mpd trace" command.
However, when I try to start comsol server with command "comsol -nn 2 server" I get a whole slew of warnings and errors. Below is what I'm seeing in the way of errors.
Note: If I do "comsol -nn 1 server" it does in fact start on the node that I have the VNC session on. I thought maybe that was enough, but I get the same error in the log part of comsol's GUI if I connect to the server running on that 1 node.
Talking to the computing guys at school (they're stumped too) it's probably an X11 forwarding issue. Specifically, they noted that comsol calls ssh with -x command not -X (-x actually turns off X11 forwarding I think)....I'm looking for a way to get this going.
Any help is much appreciated!!
Thanks! --Matt
Output from "comsol -nn 2 server" command:
No Protocol Specified
(Comsollauncher:15553): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(Comsollauncher:15553): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
(Comsollauncher:15553): Gtk-CRITICAL **: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
(Comsollauncher:15553): GLib-GObject-CRITICAL **: g_object_get: assertion `G_IS_OBJECT (object)' failed
(Comsollauncher:15553): GLib-GObject-WARNING **: value "TRUE" of type `gboolean' is invalid or out of range for property `visible' of type `gboolean'
(Comsollauncher:15553): Gtk-WARNING **: Screen for GtkWindow not set; you must always set
a screen for a GtkWindow before using the window
(Comsollauncher:15553): Gdk-CRITICAL **: gdk_pango_context_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_context_set_font_description: assertion `context != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_context_set_base_dir: assertion `context != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_context_set_language: assertion `context != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_new: assertion `context != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_set_text: assertion `layout != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_set_attributes: assertion `layout != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_set_alignment: assertion `layout != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_set_ellipsize: assertion `PANGO_IS_LAYOUT (layout)' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_set_single_paragraph_mode: assertion `PANGO_IS_LAYOUT (layout)' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_set_width: assertion `layout != NULL' failed
(Comsollauncher:15553): Pango-CRITICAL **: pango_layout_get_extents: assertion `layout != NULL' failed
(Comsollauncher:15553): Gtk-CRITICAL **: gtk_icon_theme_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
(Comsollauncher:15553): Gtk-CRITICAL **: gtk_icon_size_lookup_for_settings: assertion `GTK_IS_SETTINGS (settings)' failed
(Comsollauncher:15553): Gtk-WARNING **: Invalid icon size 6
(Comsollauncher:15553): Gtk-CRITICAL **: gtk_icon_theme_load_icon: assertion `GTK_IS_ICON_THEME (icon_theme)' failed
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f5107e70bf1, pid=15553, tid=139987637663472
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode linux-amd64 )
# Problematic frame:
# C [libgtk-x11-2.0.so.0+0xffbf1] gtk_icon_set_render_icon+0x721
# An error report file with more information is saved as:
# /tmp/hs_err_pid15553.log
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Thanks! --Matt
3 Replies Last Post 5 mag 2011, 17:10 GMT-4
