5.3a parametric sweep
Hello, I am performing a parametric sweep study, however comsol gives the error message "Parameters: "thick","0.01" The following feature has encountered a problem: - Feature: Parametric 1 (sol1/s1/p1) - Feature: Stationary Solver 1 (sol1/s1) Parameter names must not be empty."
I am amazed something that didn't happen previously is causing an error in the latest version. I also found a similar error for multiphysics - Nonisothermal flow coupling where it causes an error with "reference density" not defined. I would like to know if this is an issue with the version, or something has changed and if I need to change something. I haven't faced these issues previously.
Thanks -Sai
1 Reply Last Post 14 mar 2018, 15:18 CET
Posted: 7 years ago 14 mar 2018, 15:18 CET
Hi Sai,
If possible, please submit your model to support. It is difficult to guess what is the problem, but you can try to regenerate the solver sequence (Reset solver sequence to default on Solver configuration).
Henrik
Henrik Sönnerlind
COMSOL
Hi Sai, If possible, please submit your model to support. It is difficult to guess what is the problem, but you can try to regenerate the solver sequence (*Reset solver sequence to default* on *Solver configuration*). Regards, Henrik
