Heat conduction in 2D model
Posted 10 set 2017, 07:21 GMT-4 Heat Transfer & Phase Change, Materials Version 5.3 1 Reply
Hi, I am a beginner and I need help for a heat conduction simulation.
I have a 2D model of a hollow rectangular plastic case (thickness around 1mm) with a thin copper layer attached to one of the inner sides of the case. A heat source should be applied from the external environment and I want to evaluate the temperature response of the copper layer. Inside and outside the case there should be air (I don't know how to assign it because it is an empty space and i can't select it)
How should I proceed? How can I run the simulation?
Thanks in advance
Thanks in advance
1 Reply Last Post 11 set 2017, 02:20 GMT-4
