Import multiple STL file
Hi all,
I have 10 STL file that construct an object, I have tried to import them in the regular way, i could import one, when i begin importing the second it will erase the first.
Is there any option or any alternative method ?
Thank you in advance,
Juliano
1 Reply Last Post 4 feb 2011, 19:35 CET
Posted: 1 decade ago 4 feb 2011, 19:35 CET
I believe there was a limitation to one file in 3.5, but I do not believe tis is anylonger the case in v4 (must admit I havent tried)
Hi I believe there was a limitation to one file in 3.5, but I do not believe tis is anylonger the case in v4 (must admit I havent tried) -- Good luck Ivar
