flux boundary condition in transport of diluted species
Posted 7 ott 2016, 04:16 GMT-4 Version 5.1, Version 5.2 1 Reply
Dear all
I am quite new to COMSOL although I am not new in developing codes. I am trying to understand the boundary conditions (flux) in transport of diluted species, as my goal is to make a time dependent charge transport model.
I made a simple 1D code, linking Poisson equation (variable V) with transport of diluted species. I want to add a specific condition for the flux at a boundary.
+ First of all, I checked the value of this flux when the 'no flux' option is chosen. And, from what I understood, the result is not zero (which is a bit surprising to me) but depends on the tolerance you chose. But what is more surprising is that if I run the same simulation several times, I always find different values of this boundary flux tds.bndFlux-xxx (one to two orders of magnitude, different sign). I would like to know why?
+ then I want to specify a value for this flux (option 'Flux' with a constant value first). What is the direction of the inward flux? is it always directed from outside to inside?
+ the boundary flux that I want to add is very small compared to the other values of potential or species density. This value is more or less of the same order of magnitude that the error that COMSOL makes when calculating it. As this is not a dependent variable of the model, can I apply a 'tolerance 'on it?
Thank you in advance.
Séverine
Séverine
1 Reply Last Post 11 ott 2016, 01:58 GMT-4
