solution as initial condition.!
Posted 6 lug 2016, 09:23 GMT-4 Fluid & Heat, Studies & Solvers Version 5.2 0 Replies
I have solved a model of flow over a sphere initially with stationary solver, and I have used this stationary solution, as initial condition for further time dependent study. I got the results but little over predicted.
to trouble shoot the problem, I checked that the drag value from stationary solution is not matching with drag value I got from time dependent solver at t = 0.
Here I think since I have given the stationary solution as initial condition for time dependent study. The value of all variable solved for and not solved for should be same at time t = 0 ?
can somebody please tell me about some possible mistakes I might did?
I am using solution as values of variable solved for as well as value of variable not solved for.
thanks and regards
Atul
Hello Atul Bhagat
