24 nov 2010, 14:31 CET
you mustt apply a vector expressed load then with 2-3 components (for 2D 3D respectively).
To write it out correctly you must think "COMSOL BC" that is the formula you write in the "GUI field" is applied onto any/all "element" of volume dxdydz located at x,y,z belonging to the boundary.
This is the "implicit" mathematical notation of COMSOL, and I have noticed very many users are not fully grasping this.
so select your boundary, define total load per unit area (respectively length for 2D) type in the vector formulas, Force *amplitude = based on the x,y,z coordinates (or any user defined CS you have set up) and divide by the total area. (Note like that you apply a mean pressure (Force/totalArea) that is a constant average valued scalar and your "amplitude function" is then givingthe vector orientation.
Have I made myself clear ? ;)
