Sven Friedel
COMSOL Employee
9 years ago
25 feb 2016, 14:34 CET
Dear Balint,
I would recommend havoing a look at the following tutorial model where space and time dependent source functions are explained:
ch.comsol.com/model/laser-heating-of-a-silicon-wafer-13835
Sven
Dear Balint,
https://ch.comsol.com/model/laser-heating-of-a-silicon-wafer-13835
Sven
9 years ago
26 feb 2016, 14:37 CET
Dear Sven,
Thanks a lot. I ended up having a "Normal Current Density" defined under my Electric Currents physics and that recognized the x,y,z parametric Gaussian current profile.
However, I have a new problem now. This Normal Current Density object needs a boundary to define
to which surface it is onto which the current should be normal to. When I want to select the surface I want
(a surface boundary from a Metal Domain) it does not allow me to do it. When I add it explicitly, knowing the number of the boundary, it write "not applicable". How can I circumvent this?
Or, perhaps shall I used another type of current density object to put current injection onto a Metal Terminal?
Balint
Dear Sven,
Balint
9 years ago
26 feb 2016, 15:31 CET
Dear Sven,
in the meantime I have another question. I am able to define Gaussian profile for my current density, using the spatial coordinates and during the solution it is correctly picked up because I can see that the "spot" due to the electrical current injection is at the position where I want after solution, and it has the right shape. But I want to add a time dependence to this current too, which does not seem to work.
I add the following expression to my current J:
J = an1(x,y,z)*gp1(t[1/us])
where an1(x,y,z) is my analytical expression for the spatial Gaussian profile (it is a product of 3 one-dimensional Gaussians),
and gp1(t[1/us]) supposed to be the time dependent part. I hope the units are correct.
Both an1 and gp1 are defined as global functions. But somehow in the solution my conductor Terminal just charges up continuously and therefore does not take into account the time dependent gp1 Gaussian.
If it does pick up the x,y,z spatial part, why it does not pick up the time dependent part? Comsol does not complain and the expression is also not "orange", no warning at all.
Balint
Dear Sven,
Balint
9 years ago
26 feb 2016, 15:40 CET
Sorry, please ignore my last question, I had the units wrong: I should've put 1/ns instead of 1/us.
Balint
Balint
9 years ago
26 feb 2016, 15:43 CET
Dear Sven,
it seems I managed to circumvent this problem by using an External Current Density and selecting the Domain of my choice. Then the parametric Gaussian analytical spatial function takes care of positioning the injected pulse to the write place.
Balint
Dear Sven,
Balint
Dear Sven,
Balint
[QUOTE]
Dear Sven,
Balint
[/QUOTE]
