Thermal expansion and joule heating
I am trying to model the thermal expansion and joule heating physics in a complex model in Comsol. At the moment I am using just a simple cable, where I want to apply a current source of 900A for a period of time and check the results. I attach the model.
I don't have any information regarding the voltage, so I just assumed a 30 kV source, but I am not sure if it is needed at all.
Also it seems, I have some problems, when using the electrical power dissipation as a heat source.
Please can you check it and advice?
For any question, please let me know.
Kind regards,
Pavlos.
1 Reply Last Post 23 nov 2015, 18:01 CET
Posted: 10 years ago 23 nov 2015, 18:01 CET
Hello Pavlos,
Your electric boundary conditions appear incorrectly set up. I would expect a known voltage (or total current) at one end and a ground at the other. In any case, the Busbar tutorial in the Application Library includes detailed instructions on how to set up a model combining those physics. That model is found also in the Introduction to COMSOL Multiphysics manual, which you can access through File > Help > Documentation, and also here: www.comsol.com/documentatio/IntroductionToCOMSOLMultiphysics.pdf
Hello Pavlos, Your electric boundary conditions appear incorrectly set up. I would expect a known voltage (or total current) at one end and a ground at the other. In any case, the Busbar tutorial in the Application Library includes detailed instructions on how to set up a model combining those physics. That model is found also in the Introduction to COMSOL Multiphysics manual, which you can access through File > Help > Documentation, and also here: www.comsol.com/documentatio/IntroductionToCOMSOLMultiphysics.pdf Best, Jeff
