How can I input a heavy oil properties?
Posted 19 set 2010, 17:13 GMT-4 1 Reply
I am trying to use COMSOL to simulate a reservoir, but there is no related materials in library built-in.
For example, how can I input the saturation, permeability and temperature-dependent conductivity?
Whether can I use matlab to define the above properties?
or I should build a file with *.txt format then import it? If so, what kind of the txt file should be like?
Thank you very much.
1 Reply Last Post 20 set 2010, 05:40 GMT-4
