Meshing errors
I am trying to run a parametric sweep with 2 parameters and i am facing a couple of problems during my simulation and i would be very pleased if you could help me.
The first error is:
Failed to evaluate variable.
- Variable: material.k21
- Geometry: 1
- Domain: 18
- Variable: mod1.ht.kyx
- Defined as: material.k21
- Variable: mod1.ht.k_effyx
- Defined as: mod1.ht.kyx
- Expression: d((-(mod1.ht.k_effxx*mod1.Tx+mod1.ht.k_effxy*mod1.Ty+mod1.ht.k_effxz*mod1.Tz)*test(mod1.Tx)-(mod1.ht.k_effyx*mod1.Tx+mod1.ht.k_effyy*mod1.Ty+mod1.ht.k_effyz*mod1.Tz)*test(mod1.Ty)-(mod1.ht.k_effzx*mod1.Tx+mod1.ht.k_effzy*mod1.Ty+mod1.ht.k_effzz*mod1.Tz)*test(mod1.Tz))*(dvol),{test@4})
And when I erased the Domain 18 to see what happen i face the second error.
The second error is:
A problem arose when building mesh feature 'Free Tetrahedral 1'.
Failed to generate mesh for domain.
- Domain: 1
Failed to insert point.
- x-coordinate: -413.356
- y-coordinate: -50.4578
- z-coordinate: -103
Internal error in mesh initialization.
- Detail: Failed to determine cavity.
Error in multiphysics compilation
Unfortunately i can't attached the file because of its size.
Thank you in advance for your help and your precious time,
Michalis
2 Replies Last Post 6 nov 2015, 06:59 GMT-5
Posted: 1 decade ago 6 nov 2015, 06:24 GMT-5
You can probably attach the file if you clear all the studies (top ribbon).
Posted: 1 decade ago 6 nov 2015, 06:59 GMT-5
Thank you Lasse.Is always good when more experience comsol users helps you.
