How to change image propertiesin the reports node?
I want to create a "report" with a few of my Plot Groups. However the resulting image is impossible to change parameters for it seams. For example even though a plot group does not show the legend it shows up in the report. Since I have >50 solutions the resulting image then only shows a legen over the entire figure.
How can I change the properties for the resulting images that is generated for the report? (BTW changing to "Extra Large" size does not help)
1 Reply Last Post 5 nov 2015, 05:44 GMT-5
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 5 nov 2015, 05:44 GMT-5
Hi Micke,
This is unfortunately a bug in version 5.1. It has been fixed in the upcoming COMSOL version 5.2. In the meantime, there is a workaround that you can use to avoid showing legends in the report:
Enable the "Show legends" setting in the plot group node and then disable the same setting in the plot nodes for that plot group.
Magnus Ringh, COMSOL
Hi Micke, This is unfortunately a bug in version 5.1. It has been fixed in the upcoming COMSOL version 5.2. In the meantime, there is a workaround that you can use to avoid showing legends in the report: Enable the "Show legends" setting in the plot group node and then disable the same setting in the plot nodes for that plot group. Best regards, Magnus Ringh, COMSOL
