first time user need help
Hi guys,
this is my first time to use this software (COMSOL Multiphysics ), I am studying a heat transfer in greenhouse on prototype made of acrylic sheets.
I just need help if possible to do a 2D simulation of the heat transfer on a single wall 6mm thick and measure the heat loss through the wall, the temperature inside is 30C and the out side is 19C.
it will appreciated if anyone could help me with that or direct to a guide that have similar situation. that can help me as well to do a 3D model.
thanks in advance, and inform me it if my details are missing or wrong
3 Replies Last Post 12 ott 2015, 13:41 GMT-4
Posted: 1 decade ago 12 ott 2015, 02:14 GMT-4
Here a veryvery simple model.
BR
Lasse
Here a veryvery simple model. BR Lasse
Posted: 1 decade ago 12 ott 2015, 09:25 GMT-4
thank you sir.
just 1 question, How can I plot a temperature graph
thank you sir. just 1 question, How can I plot a temperature graph
Posted: 1 decade ago 12 ott 2015, 13:41 GMT-4
A surface plot is formed by default, but since the solid (glass) domain has the variable T and the air domains the variable T2, I have defined a new variable "Temp" which is T in glass and T2 in air. Now I can plot "Temp" i.e. the temperature distribution across the entire model. I think that is done in the 1D plot that I added in the end of the script, look at it.
BR
Lasse
A surface plot is formed by default, but since the solid (glass) domain has the variable T and the air domains the variable T2, I have defined a new variable "Temp" which is T in glass and T2 in air. Now I can plot "Temp" i.e. the temperature distribution across the entire model. I think that is done in the 1D plot that I added in the end of the script, look at it. BR Lasse
