Developing a 3D Undulating Geometric Surface Using Comsol Multiphysics
I have been trying to develop a 3-dimensional undulating surface in the x-direction. Find attached a figure explaining my geometry. If someone have any idea on how to develop this geometry. I will be happy to know. The Geometry is a hemisphere with an undulating surface along the flat plane. Thank you.
3 Replies Last Post 9 ott 2015, 15:53 GMT-4
Posted: 10 years ago 9 ott 2015, 13:25 GMT-4
You can use a Parametric Surface node for this purpose.
You can use a Parametric Surface node for this purpose. Best regards, Jeff
Posted: 10 years ago 9 ott 2015, 13:33 GMT-4
I try using the parametric surface. The parametric surface is not behaving like a solid so I can enforce a boundary condition over the surface. The hemisphere is a solid.
Posted: 10 years ago 9 ott 2015, 15:53 GMT-4
Updated: 7 years ago 31 gen 2019, 09:40 GMT-5
The idea is to use the parametric surface to partition a sphere into two chunks, one of which you then delete.
The idea is to use the parametric surface to partition a sphere into two chunks, one of which you then delete. Best, Jeff
