Andrew Prudil
Nuclear Materials
20 ago 2010, 19:35 CEST
Not entirely sure this will work, but you can try using the mat notation.
For the Young's modulus of the first material you would use "mat1.E". Although this is annoying that you can't use the material name, it might let you do what you are trying to accomplish.
25 ago 2010, 04:57 CEST
Thank you for your response.
When I tried this, I used mat1.E in the expression for the function I wanted to define, but COMSOL returned an error that mat1.E is an undefined variable. Is there something else I need to do for COMSOL to recognize the mat1.E notation?
25 ago 2010, 11:30 CEST
it might be mat2 if you have defined 2 materials, you can check this either by studying the eqautions, looking into the "history file (v3.5) or save the file A COPY as an "m" file (note: in V4 you cannot open an "m" file witout passing via matlab if I remember right) and take a look on the inside code.
The access via the mat#._whatever_ is slightly tricky and depends on the history of you modelling, ad could be (to be hecked) changed again if you do a File model reset
26 ago 2010, 15:20 CEST
I am using Comsol 4.0. I was able to confirm the material is mat1, but there were some old definitions in the m file. In addition, I noticed references in the m file to what appeared to be variables for "youngsmodulus" and "poissonsratio" rather than variables "E" and "nu" as I expected. I reset the file history and tried again using both E and youngsmodulus as variable names, but continued to get undefined variable errors reported. Is this notation explained anywhere in the documentation? Could this problem be a result of using the material parameters from the basic physics in the piezoelectric physics section?
Thanks for any additional insights.
26 ago 2010, 17:04 CEST
If I have understood the Comsol approach correct, we are supposed to assign material to domains and access the variables via the domain indexes in an indirect way.
By addressing directly the mat# we are one level deeper and interfere easier with the COMSOL internals, and two masteer cooks on the same dish never give a good result ;)
COMSOl uses several level of names to hierarchy thme depending where they are accessed, we are supposed to interact directly with last" highest level
Unfortunately, This is probably not helping you much
