Can't use parameter as frequency in boundary mode analysis
Posted 17 lug 2015, 12:32 GMT-4 Parameters, Variables, & Functions Version 5.0 1 Reply
I'm trying to do a boundary mode analysis. If I type in a numeric frequency under "Mode analysis frequency" it works. But if I put "c_const/lambda" in for frequency, it says failed to evaluate variable even though lambda is defined in Global->Definitions. Even if I define a variable "foo" as c_const/lambda in Global -> Definitions, and can see the correct numeric value calculated there, if I use this parameter "foo" for analysis frequency, it fails.
Is this a bug, or am I misunderstanding something?
1 Reply Last Post 31 lug 2015, 11:41 GMT-4
