7 lug 2015, 05:17 GMT-4
Can you not use the two physics in one model file? It might make things smooth for you.
Anyway, it might be possible using Matlab interface. Define a Matlab function in the model file that needs input from the other. The first model will call the matlab function to seek values of the variable and that matlab function will execute the other model in turn and provide results to the first.
7 lug 2015, 05:55 GMT-4
Thank you for your reply.
I through that building such system in one model it will create a very complicated model to solve. I think I will use the matlab function to create an ambient temperature variable.
Please advice whether creating HCPV and TES system in model is a good idea or not?
[QUOTE]
[/QUOTE]
8 lug 2015, 03:07 GMT-4
Adding multiple physics interfaces in one model should be the best approach. Comsol has been designed so as to facilitate those applications. I will suggest you to try out the matlab trick only if the former turns out too be difficult.
The rest I do not know much about.
