Substracting a coil from a pipe
Posted 26 mag 2015, 11:44 GMT-4 2 Replies
I am building a barrel to wind a wire on to.
The helix i defined with the primitive geometry
The barrel wire is mounted on, i have swept a square work plane along a parametric equation, of the helix.
To make the barrel i just then defined two cylinders,
thought i could just use use a boolean operator to subtract the square cross section helix.
Please find attached,
Many thanks
Many thanks
2 Replies Last Post 27 mag 2015, 04:40 GMT-4
