Postprocessing
I am new to COMSOL and using 3.5a version. I wanted to know if there is any way I can the result data as excel sheet or a matlab file. Like, suppose I simulate flow of water in a cylinder and I want to know the velocity in the entire domain. How do I get that?
Thanks in advance
1 Reply Last Post 13 lug 2010, 08:46 CEST
Posted: 1 decade ago 13 lug 2010, 08:46 CEST
with matlab you can fetch al the data and reintepolate it with "postinter()" into an array for "private processing" see the command.pdf doc amnd the matlab interface
Hi with matlab you can fetch al the data and reintepolate it with "postinter()" into an array for "private processing" see the command.pdf doc amnd the matlab interface Good luck Ivar
