error in opening zip file
I would to do an electrostatics simulation. So I tried loading some of Dr. Walus' examples.
But when I try opening any one of those .mph's I get the abovementioned error! The only exception being the 3P_Pointcharge.mph example. Could this be a version incompatibility (I have v. 4.0.0.929)?
2 Replies Last Post 13 set 2011, 22:07 CEST
Posted: 1 decade ago 10 lug 2010, 21:27 CEST
You can only read in 3.5a models in V4, so you need to open older models in 3.5a, then save them in this format before loading them into V4.
I have also seen the "zip" error for 3.3 and older versions
Hi You can only read in 3.5a models in V4, so you need to open older models in 3.5a, then save them in this format before loading them into V4. I have also seen the "zip" error for 3.3 and older versions Good luck Ivar
Posted: 1 decade ago 13 set 2011, 22:07 CEST
For solving out given trouble you may use various effective instruments such as www.zipfilerecovery.org which allowing to view the results of working, it works under any system requirements. Can rapidly repairing corrupted or lost zip files.
For solving out given trouble you may use various effective instruments such as http://www.zipfilerecovery.org which allowing to view the results of working, it works under any system requirements. Can rapidly repairing corrupted or lost zip files.
