Changing a curve to surface
Hi all,
I have a design which I created in AutoCAD and imported to comsol.The design is a combination of curves which I intend converting to a 2D surface.Can someone please help
I have attached a sample of my comsol file.
Thanks.
1 Reply Last Post 29 apr 2015, 10:59 GMT-4
Frank van Gool COMSOL Employee
Posted: 1 decade ago 29 apr 2015, 10:59 GMT-4
Dear Olufemi,
check that there are no holes in your lines (near 20;23.4 you have a small hole).
After fixing that you can "convert to solid", and then delete the internals of your block.
If you removed the hole in autocad, and alternative would be to set the import to "form solids".
Frank
Dear Olufemi, check that there are no holes in your lines (near 20;23.4 you have a small hole). After fixing that you can "convert to solid", and then delete the internals of your block. If you removed the hole in autocad, and alternative would be to set the import to "form solids". Best regards, Frank
