Using only part of saved solution Comsol v4.4
Posted 16 apr 2015, 08:26 GMT-4 Acoustics & Vibrations, Studies & Solvers Version 4.4 0 Replies
I am studying the acoustic response of a spherical shell. I am doing an acoustic-solid interaction study (frequency domain). I would like to study the acoustic field generated by an oscillating shell in its quadrupole mode.
I would like to go in two steps. In the first, I use a background plane wave in order to excite the shell to one of its modes. In the second, I give the displacement field calculated in the first step as a initial value, disable the background field and solve again in the frequency domain. I hope that the approach is not totally wrong :)
In the acoustic module I am using, my dependent variables are the displacement field and the pressure field. Looking into the forum, however, I only found posts about keeping the whole solution of a previous step as an initial condition for the second step, regarding the dependent variables. I would like to keep only the displacement field because I would like the pressure field for the second step to be 0. How is it possible to do that?
Thank you in advance for your help,
Alessio Caciagli
Hello Alessio Caciagli
