Time-dependent heat flux as boundary condition
Posted 11 giu 2010, 01:05 CEST Heat Transfer & Phase Change, Heat Transfer Version 4.1 1 Reply
I am running a case where my boundary condition is heat flux, and it varies over time following a Gaussian curve over a day. I have tried my case setting a polynomial of 6th degree as the Boundary setting , calling it qvar and changing the equations to read it as input for q0_ht, in the heat transfer section of Multiphysics.
I am not getting reasonable results, no sure if COMSOL can not simulate time-dependent BC altough the literature says it can. The questions is how does this time-dependent heat flux should be entered in my case???
Is there a problem for running COMSOL for as long as 1 days (in seconds 1:3600:86400) in the solver? Can COMSOL do it or is there a method of running a series of transient cases. restarting from the previous one.
I mean , my first case at 00:00 hrs, the run it transient for 1 hours , and use this case results as input for the following hour, so that I have a total of 24 cases?
I really would appreciate your help since I have been reading papers and attempting different way of inputing this heat flux for a while. It is relatively easy to just input a single value but my boundary condition does actually change throughout the 24 hours.
I can send you mi case if you need it, actually I already contacted Support since Monday night and nobady has replied my message!!!
Virginia
Hello Virginia Ruiz
