Distortion after CAD-file import
i have imported a CAD Data file (parasolid) which was constructed with Solidworks to Comsol 4.0.
The assembly consists of two parts. one thin layer (thickness: 0.02 mm, a high resistive medium) in which a circular hole (radius: 0.125mm) is included. In this hole the second part ( thickness: 0.02 mm, pads with same radius as hole) is located.
After the import to Comsol the structure looks like the following.
The circumferences of the hole of the thin layer are distorted (torsion) , however the pad can be identified by a nice circular shape.
Does anybody know why this occur and how do i can adapt the thin layer to the hole (like perfectly aligned as assembled in Solidworks)? As i understand now, i am only able to delete faces and so on, but not adapt the geometry somehow?
Thanks for your time and consideration,
Severin
2 Replies Last Post 31 mag 2010, 16:47 GMT-4
Posted: 2 decades ago 29 mag 2010, 05:03 GMT-4
there should be no distortions when you import parasolids from SolidWorks, I havent tried it out extensively yet for small features for V4. In V3.5 you need to check the "repair" tolerance, there is certainly one in V4 too.
Do you mind distributing your x_t for us other to try too ?
Or send it to support, so they could check, but pls keep us oher here informed if there is a trick or a bug ;)
Have fun Comsoling
Hi there should be no distortions when you import parasolids from SolidWorks, I havent tried it out extensively yet for small features for V4. In V3.5 you need to check the "repair" tolerance, there is certainly one in V4 too. Do you mind distributing your x_t for us other to try too ? Or send it to support, so they could check, but pls keep us oher here informed if there is a trick or a bug ;) Have fun Comsoling Ivar
Posted: 2 decades ago 31 mag 2010, 16:47 GMT-4
Hi Ivar,
after a few hours of try and error I have found out that with an graphics card driver update the problem can be solved.
Thanks for your help,
Severin
Hi Ivar, after a few hours of try and error I have found out that with an graphics card driver update the problem can be solved. Thanks for your help, Severin
