band gap phononic crystal help
I am new to Comsol and trying to calculate simple 2D, band gap but I am lost. Any instructions or tutorials please.
Thank you.
5 Replies Last Post 25 gen 2016, 18:47 CET
Posted: 1 decade ago 23 dic 2014, 06:44 CET
You might start with the photonic band gap example in wave optics module. Settings of these two simulations are quite the same.
Posted: 1 decade ago 10 giu 2015, 23:45 CEST
thanks for your suggestion, but I am using comsol 4.4 and I do not have wave optics module, and I am lost while trying to modify the photonic crystal example.
But I have done some thing like following (2D square Lattice, solid cylinder in solid matrix),but I did not get the z-mode (longitudinal mode), just the transverse mode only:
1. used acoustic-structure interaction, elastic wave (elw) module
2. chose both domain linear elastic material.
3. Floquet periodicity (1,4) and (2,3) boundaries.
4. took the parametric sweep for kx = 0 to pi/a
5. finally got kx vs freq (derived values > global evaluation),
but this kx vs freq gave me just transverse modes only, longitudinal mode missing. I am lost. Please suggest me how to get longitudinal modes.
Also I am having problem with liquid matrix with solid scatterer.
Thank You.
thanks for your suggestion, but I am using comsol 4.4 and I do not have wave optics module, and I am lost while trying to modify the photonic crystal example. But I have done some thing like following (2D square Lattice, solid cylinder in solid matrix),but I did not get the z-mode (longitudinal mode), just the transverse mode only: 1. used acoustic-structure interaction, elastic wave (elw) module 2. chose both domain linear elastic material. 3. Floquet periodicity (1,4) and (2,3) boundaries. 4. took the parametric sweep for kx = 0 to pi/a 5. finally got kx vs freq (derived values > global evaluation), but this kx vs freq gave me just transverse modes only, longitudinal mode missing. I am lost. Please suggest me how to get longitudinal modes. Also I am having problem with liquid matrix with solid scatterer. Thank You.
Posted: 1 decade ago 24 giu 2015, 02:54 CEST
Thank You.
Hi Ukesh,
As far as I know, elastic waves include one longitudinal and one transverse waves while z-mode is referred as another transverse wave. I have problems with simulation of z-mode too. I have tried to ask help from COMSOL technique support. Unfortunately, they said currently it's very difficult to simulate z-mode in COMSOL.
As for the liquid-solid case simulation, I think you may try the Pressure Acoustic module since transverse waves can not propagate in liquid or air while PA module deals with longitudinal wave like sound wave.
[QUOTE] But I have done some thing like following (2D square Lattice, solid cylinder in solid matrix),but I did not get the z-mode (longitudinal mode), just the transverse mode only: but this kx vs freq gave me just transverse modes only, longitudinal mode missing. I am lost. Please suggest me how to get longitudinal modes. Also I am having problem with liquid matrix with solid scatterer. Thank You. [/QUOTE] Hi Ukesh, As far as I know, elastic waves include one longitudinal and one transverse waves while z-mode is referred as another transverse wave. I have problems with simulation of z-mode too. I have tried to ask help from COMSOL technique support. Unfortunately, they said currently it's very difficult to simulate z-mode in COMSOL. As for the liquid-solid case simulation, I think you may try the Pressure Acoustic module since transverse waves can not propagate in liquid or air while PA module deals with longitudinal wave like sound wave. Best,
Posted: 1 decade ago 24 giu 2015, 20:45 CEST
Hi Yangfan,
Thank You very much for your response. I have tried "Pressure acoustic module" for 2D square water matrix and copper cylinder. I chose pressure acoustics for water domain, and then have to choose linear elastic material for copper, COMSOL makes the BC on the boundary between the copper-water as "Sound Hard Boundary". By doing so I got eigenfrequencies but some of the values are "NaN". I plot the band structure but not sure whether it is right or wrong.
Moreover, I have tried "Acoustic-structure Interaction module", Water = pressure acoustic; Copper = linear elastic material; BC on the boundary of the copper-water = Acoustic-structure boundary. Here too, I got some NaN values for eigenfrequencies, I still got the plot.
There is slight difference between above two band structure plots, I think this is due to the different BC used between copper and water matrix. Not sure I am in the right direction or not. Please correct me if I am doing anything wrong.
Thank you,
Ukesh
Hi Yangfan, Thank You very much for your response. I have tried "Pressure acoustic module" for 2D square water matrix and copper cylinder. I chose pressure acoustics for water domain, and then have to choose linear elastic material for copper, COMSOL makes the BC on the boundary between the copper-water as "Sound Hard Boundary". By doing so I got eigenfrequencies but some of the values are "NaN". I plot the band structure but not sure whether it is right or wrong. Moreover, I have tried "Acoustic-structure Interaction module", Water = pressure acoustic; Copper = linear elastic material; BC on the boundary of the copper-water = Acoustic-structure boundary. Here too, I got some NaN values for eigenfrequencies, I still got the plot. There is slight difference between above two band structure plots, I think this is due to the different BC used between copper and water matrix. Not sure I am in the right direction or not. Please correct me if I am doing anything wrong. Thank you, Ukesh
Posted: 10 years ago 25 gen 2016, 18:47 CET
I uploaded a COMSOL file to the Model Exchange that shows how to set up a phononic band gap eigenfrequency analysis. Here is the link: www.comsol.com/community/exchange/432/.
Nagi Elabbasi
Veryst Engineering
I uploaded a COMSOL file to the Model Exchange that shows how to set up a phononic band gap eigenfrequency analysis. Here is the link: http://www.comsol.com/community/exchange/432/. Nagi Elabbasi Veryst Engineering
