switch to 64bit - new licence required???
Hello, my question is not very physical but nevertheless i need a good answer urgently..
It is about our Comsol licence:
As we want to simulate a large geometrical probem we are running out of memory at the moment.
So we are planning to install a 64-bit windows system on our computer to make fully use of our 4GB memory capacity. But now we are afraid that if we install a 64bit windows on our computer, comsol might no longer work because our licence is limited to only one computer. Thus the licence might also be limited to our current windows system only...
Does anyone have an idee if this is true???
3 Replies Last Post 5 mag 2010, 05:08 GMT-4
Jim Freels mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Posted: 1 decade ago 4 mag 2010, 10:44 GMT-4
You should contact COMSOL directly about this issue. I could guess or speculate, but that would not be appropriate.
Posted: 1 decade ago 5 mag 2010, 04:35 GMT-4
There is no relationship between the OS (32/64bit) and the license that you are using. It can be used for both systems and for different OS (Win/Linux/Mac).
Hi, There is no relationship between the OS (32/64bit) and the license that you are using. It can be used for both systems and for different OS (Win/Linux/Mac).
Posted: 1 decade ago 5 mag 2010, 05:08 GMT-4
probably, but depending on the licence you have it's either floating or "motherboard locked", any how, the best is to discuss with your support or retailer
Hi probably, but depending on the licence you have it's either floating or "motherboard locked", any how, the best is to discuss with your support or retailer Ivar
