No flux boundary conditions
Hello for everybody!
I am a student of Master of Science in Petroleum Engineering, Torino, Italy. I am doing my thesis with COMSOL. The theme of my thesis is an "Application of a FEM simulator in mulltiphase flow in porous media". As a basis I am following the paper of Diaz-Viera: "COMSOL Implementation of a Multiphase Flow in Porous media"
I am trying to simulate with COMSOL a simple multiphase flow model using 1D -PDE, coefficient term-time-dependent analysis.
Let's say that I am injecting water from 1-st boundary and I would like to close the second boundary making "No flux boundary conditions". At the end I should obtain a plot with increasing pressure.
But I cannot set "no flux boundary conditions". Please, help me.
I will attach file with the model where I want to set "No flux boundary condition" for the second boundary.
Thank's in advance.
Marziya Aliyeva
3 Replies Last Post 5 lug 2010, 10:18 CEST
Posted: 2 decades ago 29 apr 2010, 10:45 CEST
There is multiphase module in COMSOL (in Chem Eng) where you can use ready made equations. Also, your problem looks like very similar to an example in Earth Science Module, two-phase, oil-water flow.
Regards
Naveed
Hi There is multiphase module in COMSOL (in Chem Eng) where you can use ready made equations. Also, your problem looks like very similar to an example in Earth Science Module, two-phase, oil-water flow. Regards Naveed
Posted: 2 decades ago 29 apr 2010, 15:30 CEST
Hi, thank's a lot for your reply.
But I must use PDE models, I shoudl put equations, expressions by myself. After doing it I should compare my model with the other softwares lwhich are based on Finite Difference method. So, that's why I am using PDE models.
Marziya Aliyeva
Hi, thank's a lot for your reply. But I must use PDE models, I shoudl put equations, expressions by myself. After doing it I should compare my model with the other softwares lwhich are based on Finite Difference method. So, that's why I am using PDE models. Best regards, Marziya Aliyeva
Posted: 1 decade ago 5 lug 2010, 10:18 CEST
Hi everybody,
Can you have a look on my COMSOL model and model description attached below. May be someone can help me with solving my problem.
Please find below the attached Word document with the description of my problem and model.
Thank you in advance.
Marziya Aliyeva
Hi everybody, Can you have a look on my COMSOL model and model description attached below. May be someone can help me with solving my problem. Please find below the attached Word document with the description of my problem and model. Thank you in advance. Best regards, Marziya Aliyeva
