Yield function & plasticity
im trying to use Comsol Strutural Mechanics Module to simulate some geotechnical problems. I created a rectangle with roller boundaries on the left, right and bottom boundary. The upper boundary is a load in the -y-direction. The expected stress state does not reach a plastic state.
Using perfectly plastic with von Mises yield function, or Drucker Prager yield function, the solver doesn't find convergence.
Moving the upper right point 0.0001m against the y-direction, the sovler finds convergence after a few seconds.
Where is the problem?
2 Replies Last Post 9 gen 2010, 15:35 GMT-5
Hello Tim Pucker
Posted: 1 decade ago 9 gen 2010, 15:35 GMT-5
You have parametric solver with a parameter "para". I did not see "para" in any of your equations.
Is your solution supposed to be in plastic region?
You have parametric solver with a parameter "para". I did not see "para" in any of your equations. Is your solution supposed to be in plastic region? [QUOTE] Hi, im trying to use Comsol Strutural Mechanics Module to simulate some geotechnical problems. I created a rectangle with roller boundaries on the left, right and bottom boundary. The upper boundary is a load in the -y-direction. The expected stress state does not reach a plastic state. Using perfectly plastic with von Mises yield function, or Drucker Prager yield function, the solver doesn't find convergence. Moving the upper right point 0.0001m against the y-direction, the sovler finds convergence after a few seconds. Where is the problem? [/QUOTE]
